Automated SCADA Functional Testing
jjack230
Aug 2017
Brisbane
Hi guys,
Currently my company has a job with a large SCADA component. We're pretty strapped for resources at the moment and so I was wondering whether there was an existing product that could perform something along the lines of FAT? Just some sort of confirmation that our SCADA is configured and operating correctly.
Thanks in advance
Hi Jon
I'm looking at something more generic. What did you have in mind?
I'm thinking something thats point to point, Simulating the IO into SCADA and comparing it to the expected output. Thinking along the lines of utilising an API or RTU.
If you want to compare the result -in the scada- then your test application must have api or direct access to the programming environment of the scada. For x a scada made in vs, then import a specific tester class. How to determine "button turns green"...
Writing and reading from the scada register in plc is much easier. It would test plc only though. I use a homemade vs app w plc drivers to run test definitions written in xl sheets.
Smartbear is a pro suite. Never used it though.
Hello, I wanted to know if there is software that performs automatic backups and version checking. Additionally, it should support multiple...
501
I have been tasked with building an inventory of all of our automation devices across multiple large sites. Most of our hardware is Rockwell and...
17
2,429
Hi All. I Used this Post as a Starting Point to get the Files: http://www.plctalk.net/qanda/showthread.php?t=80472 I Then used FTP To grab...
884
Good Evening , Looking to upgrade and automate our motor rewind shop . I was on YouTube looking at some automated coil winders .Who are the...
1,197
New management team at my company is making a big push for automated reporting and OEE. They are also don't want to make any major capital...
2,122
