Automatic Announcement
JHuff
Oct 2002
Hi all,
I am currently working on a project with Siemens PCS7 system. One of the requirements is that I need to automatically announce the start of operation for any of the Units in the system. Does anyone know how to access a modem and play a pre-recorded message over the telephone line with a Siemens PCS7 system? I have searched through Siemens website with no luck as of yet. I have also emailed for support, but that usually takes forever.
I appreciate any help!
Looks like it will work, but I was thinking more along the lines of accessing a modem on one of the computers that PCS7(WinCC) is running on by use of a script or hopefully built in functionality that.
It is definitely a good fallback if I can't do what I want.
Do you have an HMI??
This may or may not be what you are looking for, and I don;t know your system configuration, but..On one of our production lines, we have audiable alarms. When an alarm is present, it is annunciated on an HMI (Wonderware). We have some scripts within Wonderware that plays wave files (recorded by our inhouse guys) and outputs then from a pc standard audio card to a intercom system, which is broadcasted throughout the line. As far as I know, there isnt any special here. If you have an HMI, you might be able to do this really easily instead. I hope I have understood your question
Andrew
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
98
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
595
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,848
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,352
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,867
