Automatically running a rs view 32 project
srv
Aug 2010
QATAR
109
Anybody please advice me how we can run a rs view 32 project with windows XP starts(when computer turns on)
srv,
Create a shortcut with something like this and stick in the XP start folder.
"C:\Program Files\Rockwell Software\RSView\rsvrt32.exe" "C:\ProjectFolder\Project.rsv" /r
It's also in the manual.....
One last tip: If you want it to run with the window fully maximized then right click the short cut in Windows, choose properties, and change Run drop down selection from "Normal Window" to "Maximized"
Thanks for all replies.How i can directly run the project by clicking rs view 32 icon on the desktop screen.I just tried to run through rs view 32 runtime.Through that we need to select the project and run it manually.I just need to add a project shortcut on the desktop and need to run the project by clicking that icon.please advice me,how we can do that
Ok...here we go again!
Create a shortcut on your desktop instead of the start folder containing something like this....
Hmmm, apparently Srv's problem is deeper than we thought....
1. From the Windows XP Start box (normally located in the lower left corner of your screen), RIGHT-click on "Start", then select "Explore".
2. Using Windows Explorer, browse to your RSView project folder, open it, then find the *.rsv file (Your RSView Project Name.rsv). RIGHT-click on the rsv file, then select "Send To", then "Desktop (create shortcut)".
3. You are done!
What would be the use of that?
Bornwild, there is only one use of the RSView project shortcut, as requested by SRV:
...to add a project shortcut on the desktop, and [] run the project by clicking that icon.
That is all, there is nothing else that it will do! Of course there are different ways to add the shortcut icon. You can create a new shortcut and type in the path address (tends to introduce errors into the path address), OR (my method) you can browse to the file name and let Windows create the shortcut and enter the path address for you.
Thanks.I just tried that.shortcut created.But when i click on shortcut icon,rs view works with project manager window opens and need to run from there.my doubt is, can we run the project (with out project manager and click on run)direct from the shortcut.I mean when we click on shortcut initial graphics should be opened.anybody pls advice me
This is as easy as it gets....really.
1. C:\Program Files\Rockwell Software\RSView\rsvrt32.exe = the path to RSview32 Runtime executable.
2. C:\ProjectFolder\Project.rsv = Your project path and the "rsv" file for your project. You will have to change the name and path to suit your needs.
3. "/r" runs the project when it opens.
4. So to put this all together left click on your desktop create a short cut and paste the above path into the properties. It's that easy.
The easiest way to open on a specific graphic is to open the project in Works click on Startup (the little green flaggy thing) go to the start tab and check "Intial Graphic" then select your desired screen to open at start.
Do you not have a manual??
He did not say, but I think JAC means to to to the Project Manager System menu, then click "Startup" (the green flag), then from the next menu, select "Startup" again, then click "Initial Graphic", then (out of all screens in your project) select the screen that you want to open when the project is opened.
No, it is NOT as easy as it can be, really, really. No one has convinced me that it is easier to type in those long path and file names (instead of letting Windows create the shortcut and insert the long names automatically, easily, with no hassle for you).
That is all, two easy steps, no typing of long strings of characters for us poor typists, and a shortcut icon that opens exactly the file that you pointed at. If you want the project to RUN instead of just open for editing, then you can manually add the "/r" at the end of the shortcut Target string.
Hi All, I had to replace one of my drives(SIEMENS G120C) in my conveyor system. the problem I'm having is the motor is running fine in manual...
1,246
The default setting is that the operator panel runs the downloaded program automatically as soon as it gets restarted. I need to fix and check...
2,031
I'm using FactoryTalk ME version 13. I have an alarm banner that is an on top display. Whenever there is an alarm this banner becomes visible to...
908
I have a PowerFlex 40 drive that communicates with a 1756-L61 PLC via an 22-COMM-E card. There's an auxiliary contactor attached to the motor...
1,807
Hello Gents, I have got a request to stop the system at fixed times through the day (at End of Day/Night shifts) which could be done using the...
943
