Automation Direct DL-06
jseavers
Oct 2005
Central WI
112
We have a machine with a DL-06 PLC that is running production around the clock. I have very little experience with the Automation Direct stuff so bare with me. I purchased a HO-ECOM ethernet module and would like to install it in this PLC with as little down time as possible. We also have on the shelf this same DL-06 PLC as a spare. My question is could I set -up the spare PLC with the HO-ECOM card and give it a IP address at my desk then just install the HO-ECOM card in the same slot of the running PLC? All I want the ethernet card for is troubleshooting the PLC Via remote with Directsoft software. Thanks in advance for any help.
By the way, you would have had the same down time whether or not you had pre-set the IP. Setting the IP through the Ethernet link causes no disruption to the CPU's running.
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
123
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
138
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
570
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,595
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,103
