Automation Direct DL06 with F0-04 THM
David_Emmerich
Sep 2002
Smiths Grove, KY
671
I have a Automation Direct DL06 with F0-04 THM card reading temperatures at four different locations. I have followed the logic example in the manual verbatum and can see all four inputs in the control logic. The problem I am having is the temperatures all change together..i.e. all four temps raise and fall together when only one is being manipulated.
Any Ideas???
Can you zip your project and post it with a message so we can give you a more accurate solution?
OK here ya go.
Just thinking here...there would not be a wiring issue here would it? The +'s and -'s are all correct. I have the - terminals all jumped together as per the wiring diagram. Is there anything else?
This is a good one. I can't say that I have ran across this particular problem either. I think you might have a bad module.
If you would like to RA it, give us a call at (800) 633-0405. If you decide to go that route, PM me and I'll tell you who to return it to so I can check it out.
I happened to have another f0-04 thm thermocouple card and have already swapped them out to discover the same problem.
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
940
Hi everyone, I have a DL06 I'm trying to get some historical info off of. I don't have access to the actual PLC, but I have the program. I'm...
1,165
I'm new to this software, and just recently installed an F0-04 thm thermocouple card to this plc. I wrote the logic according to instruction...
1,552
I am new to PLCs just started doing this about a month ago. I want to write a ladder program using directsoft5 for DLO6 . The program should have...
4,312
A customer of mine sent me a hard copy printout of the program, I'm modifying the printout program and sending it back to him to make the...
1,751
