Automation Direct & wonderware
rick62
Jul 2013
tuscumbia al
45
trying to place a real number on wonderware display , have done this in the past but cannot seem to be able to create the right logic from DL06 plc,I have 4 plcs on this project- slc505, compact logix, and micrologix , all on net connections. everything works, even bits and outputs from DL06 to the wonderware project. but for some strange reason I cannot get a numerical display to work from the DL06. I created a project like this about a year ago, but I lost my project from the Directsoft6 on my pc, --- stuck on DL--
What DA server are you running for the DL06? I would check the logs of your DA server and see if there are any errors or warnings logged. An error in the DA server logs may give you a hint on what the problem might be.
Usually this is an issue of swapping words and/or bytes to get the Little endian, Big endian correct for the end device.
With some Wonderware Servers, a special item name is required in order to access Real data types. I know that this is true of GE and Modicon Servers.
Anyone know if you can use a DL05 and communicate to wonderware, with or without the ethernet addon. Thanks for your time.
4,555
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
141
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
147
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
585
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,618
