AutoMax Font Size
BAJ
Jan 2006
Maple Grove, MN
201
I have a customer using AutoMax Exec v4.3A. Recently, the IT dude came through and did some updates to the laptop, and somehow the fonts changed. The ladder editor in particular is very hard to use. At 100% zoom the text is illegible and at 200% (the next step up) the diplay can only fit part of a rung of logic.
Anybody know where to set the font used by the AutoMax Exec?
Thanks,
-Brad
I can do that, but that hoses up other applications. It was fine before the "upgrades".
My subject wasn't quite accurate, should have said "AutoMax Font Selection".
-Brad
If you click the upper left hand corner of the DOS window that automax runs in, you can select Properties, and there you can change Fonts, Font sizes, colors, and a few other things. I don't know where these settings are stored, but apparently your IT guy accidently changed them or deleted them. You may have to do this for each Dos window that runs with Automax. I think these settings have no effect on full-screen operation, only windowed operation. (Press Alt+Enter to toggle between the two screen modes.)
Hope this helps
Paul C.
Thanks, and I've done that for the online task manager. To be honest, I don't think that changed after the "update".
However, the ladder editor in v4 and above is Windows-based, so this won't work for my specific problem.
I appreciate all the feedback though. Any other ideas?
-Brad
Good Morning All! I have a machine we recently install with an Automax control and Drive system. I need to maintain this and make improvements...
615
Good day everyone. I am installing a used machine with an Automax control and drive interface system. This rack has 2 processors a 57C435 and a...
1,988
We just got a new to us, used machine. It has 2 Automax racks with 3 Drives and associated I/O. How does a person print out the blk files to look...
17
3,883
Hi all, i have system running reliance automax plc system and drive system. The scada systems are wonderware intouch ver 5.0b. the automax plc...
1,454
Anyone seen remote I/O adapter with fault flashing and says "ESO LOS"
1,450
