AUX1 bus connection
spandy16
Dec 2012
Germany
58
I have a SIEMENS IM 151-8 PN/DP CPU and connected with it is a power module and a 4SI IO-Link interface. Both the modules are mounted on their terminal modules respectively. There is an availability for AUX1 bus potential connection. But in the documentation it's not clearly given. I want to connect 3 wire sensor to the terminal module, then how should I get the ground potential from the AUX1 bus ?
Hi!
You should be helped by using the ET200S configurator:
https://eb.automation.siemens.com/m...activeTab=config&regionUrl=/#activetab=config
OOps! I can see that the complexity has increased terribly since I last used it.
I put in an example config just to see the potential distribution, but I'm not able to find the button that displays it anymore.:unsure:
Kalle
Edit: Button found. I tried with IE and German language, and now it seem to work OK.
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
39
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
157
113
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
134
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
268
