[B]Mitsubishi FX Programming protocol[/B]
quarantasei
Oct 2009
bangalore
How is it possible to communicate with an FX PLC (FX3U) using 19200 bps or an odd parity through programming protocol? Currently I am only able to do this with the default settings 9600,E,7,1.
Is this via gxdev or through a opc server? Merely change settings under ONLINE - TRANSFER SETTINGS. Set it to 115200. FX3U supports max baud rate. Leave rest as is.
How about parity, data bits or stop bits? I tried changing these and i am unable to communicate with PLC. (I am using gxdev)
Actually I have another application which uses the programming protocol to communicate with the PLC. But I am not able to change the COM parameters on PLC and communicate through my application. Is there any way to set the programming port parameters to 19200, odd parity, 8 data bits, 2stop bits?
I fyou are creating a custom app in vb i recommend you use mx components. This makes life so much easier and works really well.
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
344
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
298
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
1,986
Hi, My next project is an entirely different platform, its Mitsubishi. I'm using FX Series PLC With 40 Di & 40 DO FX5 80MT and 7" Touch Screen...
3,826
Hello. I first off I wanna say that I am completely new to PLCs and am trying to help fix my Uncles hydraulic press machine that uses a Mitsubishi...
2,802
