B&R 2005 PLC communication
ngoodman
Aug 2006
Hastings
Hi has anyone ever established communication with a B&R PLC via a serial port?
I have been using a B&R OPC server via a virtual com port over ethernet but would like to talk direct from my scada package rather than via the many other bits of software running in the background.
The scada package supports C like script so coding the protocol should be OK - just need to know if it is possible and if any one knows a link to the protocols needed to read out some data from the PLC
I am sure that the B&R OPC Server (PVI ?) supports serial connections as well as ethernet.
You untind the implement a communication protocol in a script language ?
I doubt it will work.
Hello ngoodman,
we have been using serial connection to B&R by default the last years, only now switching to Ethernet.
I never was in touch until now with the B&R OPC server (will happen one of these days :) but I guess the server is running on the PLC. So, why you are using a virtual COM Port over Ethernet and not Ethernet to receive Data via PVI ?
Which protocol is your Scada using to connect to the OPC server ? Is it PVI or something else ?
br
bb
Hey NGoodman,
We work a lot with B&R, but I never heared that the protocol (INA) has been disclosed. Indeed, use OPC or PVI is the straightforward way.
We also have applications where we designed our own protocol via an ethernet connection. A server TCP/IP socket is opened on the PLC on which one or more hosts can connect to. The data-reception and sending in the PLC is taken care of by a self-written driver.
We use this to write/read a number of variables, No complicated stuff like tracing etc.
I'm sure this can be done via a (added) serial port.
Greetz,
Hi, My clients have this 16 year old, but quite good machine with B&R IPC5000, PLC 2005, ACOPOS1022 servos and some Lenze 8200 VFDs. Due to...
1,463
Below are the few details for your reference: B&R PLC Module 2005 CPU – CP152 with APM (Application Memory) Module ME Power Supply – PS477...
1,564
Hi Where can I find B&r 2005 plc - NC154 motion controller Manual and Software? Thanks in advance.
1,444
Dear Sirs, I faced problem of the a.m PLC B&R system 2005 The PLC is applied on the m/c connected to the Windows NT application program. When the...
9,519
I have a B&R 2005 plc and it looks like it uses automation studio version 4 i am try just get the program off of it so can change it to an allen...
1,059
