B&R - number of tasks
Nov 2007
Illinois
75
Hi!
I've had experience with both Mitsubishi, AB and some CodeSys PLCs. When I read the documentation, I can usually find figure for # of programs or # of tasks available.
I have been unable to find this for B&R PLCs -- I'm preparing for my first foray into using them. Trying to decide between the X20 -which I think is the low-end, and one of the other series, like the 2005, which is probably overkill, but I am trying to educate myself. Does anyone know these figures, or where they are documented? I haven't seen them in any of the datasheets or manuals I've opened so far...
B&R uses up to 8 cyclic task classes. These are similiar to AB Logix Periodic Tasks. Any number of tasks (AB equivalent of routines) may exist in the cyclic task classes. In a project last year we had about 150 tasks for controlling some 2000 I/O. Not aware of any limits to the number of tasks.
X20 has both high end and low end CPU's. The high end CPU's have similiar performance to 2005 CPU's. A X20CP1484 fits between 3CP340 and 3CP360. We mostly use a mix of 2005 / X20, mostly with 2005 CPU's since we have been using them since they were first available in the mid 1990's. Do not use 2003 or 2010.
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
134
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,108
Hi, I have this weird issue whenever I try to change the SNN from a Point IO Im missing the three ... dots to open the pop up and change it...
624
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst. One thing I don't find is a way...
711
Hi PLCs.net! I was curious: How many axis can a B&R APC910 control? Is there a hard limit like certain AB controllers? I'm new to B&R, so would...
381
