Backlight Adjustment on RedLion HMI
kay_gsr13
Oct 2011
NC
57
Is there a way to adjust the brightness of the RedLion G-series HMI? I just purchased a G308C1 and it's very dim compared to my G306A & G315C.
There is a system variable called DispBrightness that you can set. 0=off, 100=full brightness.
But I believe the units all default to 100 unless changed by the user.
The issue is that the G308C1 is much less bright than others you listed. I have found this with other vendor's 8" displays too.
The G308C1 has a brightness of 112 cd/m2, whereas the G315C is 600 cd/m2. Even the G308A2 is 450 cd/m2.
There really won't be anything you can do to make the G308C1 as bright as you would like.
Thanks kolyur and JHarbin. Jeremy Howell just replied to my email and suggested using the "DispBrightness" variable as well. Kolyur you are correct that it is default @ 100%. JHarbin is the G310 the same way?
From reading Tech Note: TNO102 (Title: Backlight Failure)
Previous version of the G308 and G310 has an issue with
"Backlight intensity grows dimmer in HMI units with Graphical Interface." How can one tell if they got on of those older units? My original firmware was Boot V71 and is now updated to Boot V77.
Thank you Kolyur, JHarbin, and Jeremy for the prompt response.
If you just purchased it, you didn't get an older one.
Again, the problem with the G308 is that it has a lower brightness (112 cd/m2). NOTHING you do will make it as bright as the G310 or G315. It's brightness value is 1/5 that of the G315.
I don't use the G308 or any other HMI even from other companies that use this technology.
Unfortunately as I mentioned in my email and what JHarbin has stated the displays you are comparing have different displays and backlights. The G308C will always be more dim than the G306A, or G308A. The brightness of each display is listed in the specifications for you comparison.
Jeremy
Hello all. We have a slight problem. Shcneider Magelis back light burned out and now it is very difficult to operate. There seems no spare parts...
74
A customer just asked me if I can replace the backlight on this Panelview Plus 600 without affecting the memory. Well.... I've programmed a...
3,539
Hello all. I have nether posted on a forum before so please bare with me. Im new to PLC programming and have been getting on quite good :0)...
1,402
Does anyone know of or have a design for replacing Allen-Bradley PanelView display backlight assemblies with an LED version? Or maybe a set of...
3,399
Hi . Please i want to help in this problem i need to change magelis backlight when alarm appare and i don't kown how i can do it ?
3,018
