Backup restore problem
kakenga
Feb 2015
Abu Dhabi
I have just received a backup file through email which I need to restore in my S7-300 CPU (with MMC).
The back up file has a .zip extension. I am using TAI PORTAL V13 SP1.
First I wanted to retrieve the file, create a project and then download it to the cpu. When I try to retrieve this file, the program can not find the file. It does not recognize it. Please advise.
It sounds like the .zip file is an archived project from Simatic Manager so I'd guess that you need to use Simatic Manager rather than TIA Portal.
It may be possible to extract the contents of the .zip file and then import the project to TIA Portal but this is not guaranteed to work and the original program must be 100% error free and consistent prior to import in TIA Portal.
Nick
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
571
Hi, Do any of you know of a tool that can easily backup and restore parameters from DBs? It would be helpful if it was easy to compare the...
2,600
Hi All, I currently have an damaged MP277-8" Touch panel (6AV6 643-OCB01-1AX1) which I am able to backup (.psb) via ProSave. We are in the...
2,835
Hey Guys, What is the difference between these three options. https://prnt.sc/1br3qbe Why there many backup software in factory talk. You have...
2,688
I would like to be able to backup and restore the values of my opc tags. Ideally I'd like to store them as XML or JSON. I have tried the tag...
2,980
