BACNet Weekly_Schedule
arons
Apr 2014
Portland, Maine
All,
I'm working with a BACNet device (KMC) and writing a driver. I was wondering if anyone has experience with the Weekly_Schedule property of Schedule Objects in BACNet. I had a few questions around these.
1. In a single Weekly_Schedule for a Schedule Object, is it common to mix BACNet data types in the time value pairs? For example <Time1><1.23>, <Time2><”Hello World”>?
2. If the answer to question #1 is “No”, is it common for the BACnet data type associated with a Schedule object to ever change?
3. Is it reasonable to require a read of a non-empty weekly schedule prior to performing the first write?
In full disclosure I work for Kepware, and we're adding support for Weekly Schedules. The BACNet spec allows a lot of things, but I'm questioning if they are used in practice. Thanks for your help!
Hi all, I have a customer who wishes to to display some of the information from their refrigeration plant (CompactLogix PLC on Ethernet/IP) on...
1,540
Anyone have success using Ignition 8 and the BACNet driver? We are going to try and read data out of our Carrier Chiller. Carrier tech is...
591
I am trying to get data from a Chiller to an AB PLC or to my SCADA system. The protocol is BACNet/Ethernet, which is a layer2 protocol distinct...
1,057
Hello, Is there any forum for the Beckhoff PLC's? I'm trying to follow an example for BACnet Building Automation where I connect a binary input...
1,192
First project working with BacNet and not having any success. Trying to read values into a Compact Logix PLC from a Kamstrup 603 Multical unit. I...
3,497
