Balluf RFID Read/Write in TIA Portal V13?
russg
Aug 2012
UK
280
has anyone done this with portal before?
I'm using a balluff RFId BIS M-41 which is communicating to a balluff IO-Link block BNI PNT-502-105-Z015.
I have an example in Step 7 classic but the way it is using pointers to the datablocks is not going to work with portal optimized datablocks.
You could use unoptimized blocks in Portal, if you don't find a better solution.
Baluff has a Function Block that you can use. In our Portal Projects it's called %FB30 "FB_BIS_COM"
Hello We integrated a BIS M-400-072-002-07-S4 (BIS0104) on a machine for the traceability system. It has to read a BIS M-110-02/L (BIS0044). We...
2,224
Hi guys, I have been tasked with job of programming a balluff rfid reader using GX Works2. The RFID is a Profibus I/O Link Slave Module...
1,728
Dear Experts i am using balluff rfid c-6002 with siemens s7-317 2 heads anyone who has worked on this rfid can help me or if possible can mail...
1,959
Hi gents, i'm working on a project where we are using some balluf I/O Modules for some inputs and outputs. I was wondering how the I/O addressing...
1,497
Hi, has anyone had experience setting up the hardware config for the these balluf blocks? I have the GSD file installed but unlike S7 classic I...
2,817
