Barcode Reader
shaulapto
Feb 2004
Raanana,Israel
53
For a packing machine application I need to connect a PLC to two fixed position barcode readers with the following specifications:
1.Up to four readings per second.
2.Reading distance about 50mm.
3.Pharmacode if it is possible.
I checked with Omron and Sick but they are too expensive for my client ($1200-$2000 each),on the other side there are some cheaper units arround $600-$700 but according with the suppliers they are not suitable for my application.
Could someone recommend a barcode reader supplier for this application?
Thanks.
three other barcode scanner manufactures that we've used other than the afore mentioned Accusort. are PSC at www.pscnet.com. www.intermec.com. The one we currently use on our high speed lableeing conveyers is a Datalogic model DS2400 which are rs232+rs485 cabable. The DS2400 is probably your least expensive.
Hello Friends Is it possible to connect a serial barcode reader to a Delta HMI? I am lookin DOP103BQ and DOP107CV. I have serch in manuals but...
1,382
Hello Friends I have a machine with a barcode reader connected through serial port to a GS2110 HMI and a FX3G CPU. Where can I found the tag...
1,624
Hello all , I have a project including S7-1200 and sick sensor lbc642 I need to communicate with the camera through ethernet tcp/I using t_send...
2,257
Hello, I am on a automotive line right now (4 segments) and we have a barcode reader at the beginning of each segment at the elevators. The...
2,289
Hi guys, I hope you are all doing well. I'm trying to connect a SICK BarCode Reader (CLV630-6120) to RSLogix in order to use it with my PLC...
4,294
