Barcode Scanner through USB
Jobu
Dec 2005
Michigan
Hello,
Has anyone interfaced a USB barcode scanner to a Panelview 400 and Micrologix 1100 or similar?
Thank you,
Jobu
Has anyone here ever used a barcode scanner to set a string register for program selection on a fanuc arm? Normally I would connect the scanner to...
1,837
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,609
I'm wondering if anyone has a solution where I can use a barcode scanner to input a string into a PLC tag. All AB hardware/software. I'm aware...
17,990
Hello Everyone. I am working on a project where I need to scan in 2 Barcodes to populate 2 different tags. A glue Batch and a product serial...
3,112
hi guys, I have to write a program to trigger and receive data from a barcode reader via an RS485 module plugged on Wago PFC 200. Does anyone know...
2,751
