Basic Omron Math Help ?
mark30504
Jul 2005
Georgia
Hello
I am in need of a bit of math help on the Omron CGS1-
I am a AB Programmer so all of the conversion to do math is a bit confusing.
I have an analog input card receiving data as UINT which I am assumening is A unsigned Decimal value, not BCD or Hex ??
I need to do a simple subtract
The value displayed is &1000 as the data value.
I am assumeing "&" stands for decimal. It seems that # stands for Hex Number, is this also correct, If so or not where can I get a listing of these prefixs ?
I want to subract 200 decimal I am guessing I can use -(410) but that says signed Binary and I am UINT ??
What would the complete command look like ?
- Analog_in &200 D110
Analog_in is my Unit, I am guessing &200 might work or do I need another memory location ?
Also, DM ... data memory. I am assumeing D110 would be Data memory location 110 ?
thanks
[email protected]
Paulus said:
Hello Mark30504,
All of your assumptions are correct.
The instruction will function OK with UINT types (data in the range 0 - FFFF hex is accepted).
For manuals, try here...
http://www.knowledge.omron.com/
if you use CX-programmer software you can see to the properties of your functions and they are have #, &, +/-, blank
I am stuck on what is likely a misunderstanding of how Omron handles data versus Rockwell. I need to scale an analog input to monitor the...
1,536
Does the basic NJ I/O unit CJ1W-MD232 work only on the EtherCAT network of the NJ.. or can it be programed to function on the NJ’s Ethernet/IP...
2,349
Hi, I am new to PLCs and would like to learn basics and possibly use them in my projects. I would like to use a PLC to generate pulses for a...
11,420
hey anyone, I'm a student from Indonesia.. I have a project, It is about how to send and receive data by serial communication between PLC Omron...
2,130
hi, Anybody knows how to program this unit?🤞🏻
3,614
