Basic Switch Wiring
th1nker
Jan 2005
Hi All,
I have a normal toggle switch and have read the faq but I'm not sure how to wire it to the inputs on the DL06. Just a bit sscard of damaging the DL06. Can some one point me in the right direciton.
Thanks, Luke
Would have helped if you mentioned what kind of toggle...momentary? maintained? single or dual contacts?
A maintained toggle is basically a switch, if it has one contact then you wire thru it to the plc input. Can depend if AC or DC which wire goest to the plc input.
The DL06 manual has wiring diagrams that show switches or contacts...if the toggle has one contact then you run thru it to 1 input on the plc.
If it has 2 contacts then you run from it to 2 inputs...in many cases the supply to the toggle can be the same but the application can make it require separate supplies. Look at Chapter 2:
http://web4.automationdirect.com/static/manuals/d006userm/d06uservol1.pdf
There is a need to be specific so the question can be answered properly.
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
128
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
229
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
424
2,003
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,097
