Bechoff Twincat 3.1 Question
quisius
Apr 2018
Brazil
Hi guys,
So I'm using Twincat 3.1 for a project, after creating the PLC under the Project Tree I created a few tags and a simple Ladder logic, just to test it out. The thing is, I can't click the "Active Configuration" button, making it impossible to go online or to simulate the program. I have build/rebuild the project before and I've also clicked the "activate boot project" option, but the "Active Configuration" button remains unavailable.
Any guesses what can I do to solve this? I think the awnser might be simple, but I just can't find how to finally use the "Active Configuration" to login and then simulate the program.
Thanks for the help!
I guess I installed just the engineering version, I tried to install a plugin called "Simulation Manager" but when I try to install it, says that I don't have twincat installed in the computer, very odd.
Hi guys, thank you all for the replys!
I just found out I had a bad installation in a Virtual Machine. I installed in my real environment and everything works fine!
hi guys, please anyone familiar with using ladder logic on twincat software for bechoff plc. i cant seem to find operands like mov,greater...
1,598
pls suggest 1. how i take back up in bechoff ipc 69xx 2. if hd crashed in beckhoff ipc, pls suggest how i installed windows s/w or restore back...
1,787
Hi I'm after some advice as to whether TwinCAT can create a *.dll file with a set of predefined variables. The reason being we are upgrading to...
40
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
353
