Beckhoff Bx9000 over VPN
lostcontrol
May 2009
NeverSayNever
1,071
What is the trick (if there is one) to accessing a Bx9000 over a VPN?
I know there is something finicky with network config when even local, when using the auto-discovery tool.
Now, nothing is discovered..
LC
ok, so the auto-discover utility does not work, but by manually adding the route via system manager does.
(I'm guessing that the standard way of doing it anyway.. :unsure: )
next question...
I have a computer on site with twincat, & my computer over VPN.
Files are shared via DropBox. When I open on computer from VPN, the file must be re-compiled & downloaded.. Is that normal, or where the compiled version is stored?
You can save the project as an archive with compile information and referenced libraries included. That way you shouldn't have any inconsistencies.
File->Save/Mail archive. Check all lines except Log File and Bitmap Files. (You can check them, but they are not necessary)
Just tried that, but how do you open it again?
Looks like it zips everything including project path libraries etc.
When I un-zipped & tried to go online, same thing...
Yeah it just creates a regular zip-archive.
What does the prompt say when you go online? External libraries have changed, or just that it needs to recompile?
Are different versions of TwinCAT 2 used?
If you download to the controller, save the project, archive the project, unzip the archive, open it and go online again, does it still want to recompile?
Nothing really, I just select Login & it re-compiles.
YES! :oops:
Remote PC is 32bit, local over VPN is 64...
Can try
Hi all, I have a machine with a Beckhoff BX9000 cpu that looses the source code every few days in the production. The name and the network...
1,648
I am newbie in using the Twincat software. I have tried to connect between Beckhoff BX9000 and Twincat. But I was not successful. In the Twincat...
5,702
Hi Has anyone tried connecting multiple PCs to a single BX9000 or BC9000/BC9050 via ADS ethernet protocol? I made two GUI application that use...
3,835
Hi I have a Beckhoff BX9000 and want to connect it via SERIAL PORT(COM1) to a TouchPanel(Weintek) that uses Modbus RTU! I downloaded the example...
3,903
Hi! I have a Beckhoff BX9000 controler and would like to make Visualisation in Visual Basic. I have tried the UDP communication and it works, I...
4,025
