Beckhoff Twincat runtime update
CX_Luigi
Sep 2010
Hong Kong
20
i bought an used CX1010 to start wetting my fingers in Twincat. The CX has Twincat 2 runtime and WinCe 6.0 installed, in my laptop I installed Twincat 3 and when trying to set a route to the PLC i always get an error 1796/ADS cannot read/write. After lot of searching in internet my understanding is that Twincat 3 installation cannot get routes to earlier runtimes, and thus i need to update/upgrade it in PLC. It is possible to update by myself the PLC with WES 2009 or later, or do i need to keep WinCE installed and update the runtime from 2 to 3? Or the upgraded runtime needs to be bought directly from Beckhoff?
Thanks for your reply Archie, but probably i was not clear in my question. I am not looking to upgrade the processor but the runtime. From what i read that should be possible, and thus the plc can have Twincat 3 runtime inside. Also the license is permanently burned in the hardware so changing the OS, whenever applicable should not be a problem.
Apologies if the questions are trivial, i am just starting and as others remarked, Beckhoff documentation while undoubtely good, needs a lot of patience to dig out relevant informations.
i understood the functionality was separated from the runtime version, and having looked at Twincat 3 i liked a lot the philosophy and use as an extension to Visual Studio.
Will follow your suggestion, and install also Twincat 2, thanks a lot Ivo
I would suggest emailing Beckhoff tech support, they should be able to tell you pretty quick what your options are for this processor. In my case (with a CX9020) they emailed me a FTP link to download the Twincat 3 runtime. (Actually it was the whole WinCE+TC image, which I just copied to the unit's SD card.)
I would expect that your TC runtime license--if you have one--would be wiped out when you upgrade the runtime. However, keep in mind that Twincat 3 has an infinitely-renewable 7-day trial license, which should be adequate if you're just using it for training.
That was my mistake, I was not clear in my post. I should have used the phrase "upgrade the processor's run-time"
Another reason I do not think it is possible, especially with WinCE, is the fact that when you order a processor you have to specify which run-time it comes pre-installed with.
as suggested by ivo_moenen, i downloaded TwinCAT2 and was able to set a route and program it. Furthermore having contacted Beckhoff support they stated the series CX10xx is only useable with TwinCAT2, not 3.
Thanks everyone for their help
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,045
Hello, I was wondering if anyone know how to upload a PLC program to the Beckhoff TwinCAT 3 from a file? i.e. without having the development pc...
761
Hi anyone got any tips and tricks?? I'm at a stage wherei need to tidy up my hmi project and give all objects sensible names, I did start this...
965
Hello, I have a System running a beckhoff IPC with twincat 2 software on it, Also i have no original source code. Is it possible with the...
1,271
Hi all, I've inherited someone else's program and can't for the life of me figure out his use of the # symbol in one of his structured text...
1,924
