Beijers Converter SC-06N - what does it do?
dkozul
Mar 2005
I found this on a jobsite where we are cleaning out a clients warehouse. what does it do / what is it used for?
it is a Beijers (Beijer Electronics)Converter SC-06N
any info would be greatly appreciated
If I am not mistaking it is a cable to connect the pc to a Mitsubishi PLC, same cable as the SC09 but older (with external power supply)
I believe it it used to program a Beijers hmi, like the MTAs for Mitsubishi (now discontinued) It should have a 9 or 25 pin cable hardwired from it, a 25 pin socket and a place for an external power supply if I remember correctly.
tommy23t
Purchase Cable
Would you be interested in selling the Beijers SC-06N cable that you mentioned in a previous forum ? Thanks Gord
I have a client with an E600 terminal in a system which I supplied to them in 2006. The E600 has now failed. I still have the E Designer .MPA file...
4,804
I have some old project on Beijers E615 panel, do you know how I can see recipes? I'm unable to locate it in a project, am I missing something? I...
1,906
I am trying to convert a Beijers MAC 50 HMI application to a new GOT application but the older system uses the Time channels function and I cannot...
1,150
Hi I have a MAC10 terminal which I need to program for non-commercail use. I understand that the SC06CN interface (the one with the 5v power...
2,514
Hi I am after replacement backlights for a couple of Mitsubishi / Beijers HMI's or part numbers, source etc I currently have the following panels...
1,993
