Beijers E1101 cables ect
exiled
Jun 2002
England
131
Anybody know what cable/interface i need to get online with a E1101?
Ive tried the cable i normally use for the E50/910 only it wont connect. i have a e1061 at home for my use and its the same.
Also there are usb ports on the hmis usb A on the 1061 & usb A&B on the 1101 What can theses be used for up/downloading program/backup ect ???
Many thanks
The E1000 series uses the CAB30 cable (LINK) for programming. By the way, you can also use a CF card or USB thumb drive to transfer programs. Ethernet is also an option. I don't know if you can use a USB cable from PC to HMI.
-Eric
I have a client with an E600 terminal in a system which I supplied to them in 2006. The E600 has now failed. I still have the E Designer .MPA file...
4,804
I have some old project on Beijers E615 panel, do you know how I can see recipes? I'm unable to locate it in a project, am I missing something? I...
1,909
I am trying to convert a Beijers MAC 50 HMI application to a new GOT application but the older system uses the Time channels function and I cannot...
1,150
Hi I have a MAC10 terminal which I need to program for non-commercail use. I understand that the SC06CN interface (the one with the 5v power...
2,514
Hi I am after replacement backlights for a couple of Mitsubishi / Beijers HMI's or part numbers, source etc I currently have the following panels...
1,994
