Belden part number
The Belden cable I have used is 3082A. As you are in Britain and if you need this quickly the RS stock No. is 331-8770.
warning
The thick cable is rated for 8 amps, but, be pre-warned
that is VERY difficult to get a good termination, as the
conductors are very small, and the insulation is very
thick and stiff. (calm down, you guys).
Seriously, the only worse cable I've worked with is
Genius cable.
If I had it to do over, I'd use the 4AMP cable, and
be done with it. Much nicer.
Can someone help me with the Belden cable # commonly used with 0-10 and 4-20 analog I/O? The cable that has the 3 conductor Blue, Brown, Black...
935
I am wiring a machine that has 2 VFD’s and using belden non armored VFD cable per spec. Does this have to run in cable tray or can it be pulled...
845
I'm adding several Lumberg (Belden) IO-Link master modules to a project in RSLogix 5000, and working through the data mapping. The manual...
1,066
I have a question, should you use fuses for all your outputs including analog? Also how should you size your fuses , just based off of your...
1,897
Belden Rev Connect. I have it, and must say, I love the system. It almost makes terminating Ethernet copper a pleasure. Okay, the connectors...
2,052
