best plc kit
manig4
Feb 2011
hi everybody,
want to know which is best PLC kit,
and very well the PLC program called simens LOGO soft,and i don't nothing else,please help the best plc regarding money,advancement, features and that software too
is it?
Is it s7 software is easy to know, because i know simens logo soft,it's easy only... any difficulties over there to learn that software
Hi, Manig4!
LOGO is programmable relay, not a PLC (LOGO can not calculate 2+2, for example).
S7-1200 is a first low-end real PLC in Siemens offer. But, programming it ...- you will have to learn a lot since S7-1200 is close to S7-300 regarding programming. Download S7-1200 Getting stared from Siemens site, to see what S7-1200 is.
You can try also Schneider TWIDO or OMRON CP1E or else...
most valuable information this is to me, i'm going learn that, thanks a lot .. and i need your help while i'm studying that.. and finally thank you very much
I would highly recommend the OMRON Micro PLC Quick Start Kit 14 I/O or one of their Lean Automation Packs as a great way to get started with PLC programming.
[And NO I do not work for or represent OMRON]
Thanks for all who are shared their valuable knowledge here,
and finally i want to tell this please suggest me most advanced plc up to date..
thank you
and go! I'll start. Always comment the Boolean instruction for their TRUE state. For example. It is much easier to read a normally closed contact...
65
21,673
Good Evening . I visited a pump station sight today that has a PLC-5/11 CPU. I was given a CD with only a file with a program and extension of...
3,820
Hi there PLC aficionados, I have a quick question for you. Do you use Linux in your integrator/automation engineer/Technician role? If, yes which...
20
8,391
Any manufacture recommendation for remote I/O for Siemens PLC.
2,938
We have an AB system that is connected to several CANbus networks via HMS gateways. A CAN message is comprised of upto eight, eight-bit bytes...
1,422
