Binary to bits
May 2010
London
689
I am not much of a programmer but about 2 years ago I made a 'cheap n cheerful' little unit that dispensed chemicals.
I used a binary selector switch to give me 0 to 7 selections using only 3 inputs.
Each one of those '8' selections set a different time to the dispensing valve.
They now want more time selections and I have 3 inputs spare but for the life of me I can't work out how many extra selections I can have with 2, 3 input binary switches.
I think 16, but maybe it's a lot more
Can you help
Oh, the plc is a small Mitsubishi FX 1n
I am not familiar with your PLC, but look for something along the lines of a Multiplex Instruction. I have used this in Omron PLCs to turn on a single Bit based on a number value. That particular one was a 4 to 16 Multiplexer. Otherwise, you will have to hand code it.
Stu...
Using GE RX3i PLC with Machine Edition SW... I have a decimal %R number (value is "1150") that I want to write to a set of 16 %I bits to set 1 and...
18
4,815
My HMI (PanelView C400 TFT Color ) won't allow me to use an output address in a Tag. So I have to map the outputs to b3 bits. Is a Move the...
2,134
Hello, I've a fast input card (1769-IQ16F) and a encoder that works in natural binary with 9 bits (845DSJDZ25ANDW4), and I need to convert this...
2,433
Hello everyone... Attached is the source code to a vb application. What I had to do was take faults off a slc/plc and attach an appropriate...
4,947
Hi folks, I'm trying to parse a binary string on a Red Lion DA30D using a Raw UDP/IP input port. I've done this before with ASCII strings so I do...
38
1,021
