"blinking" Twido
Soggy Canuck
Jan 2008
Vancouver
229
I am out in the field looking at a brick style twido plc.
The LST led rapidly pulses 3 times short pause and repeat.
Does anyone know what this means?
I am on my way out - cant help till later
it is 10:15 AM Saturday here
The Twido LAN ST LED indicates the status of the Ethernet port communications as shown in the Twido Hardware Reference Guide. However, I was unable to find the definitions for multiple blinks in the Twido Software Reference manual. I think it is safe to say that a blinking LAN ST LED indicates that your Ethernet communications port is "not ready".
Thank you all for the information. It confirms what I suspected. Trying to find this information with a smartphone and tired eyes is an exercise in frustration. Twido is not a platform I'm familiar with.
This is a standalone plc. No hmi or network attached. I suspect that whoever programmed this didn't turn of the lan settings in the first place. Should be no harm no foul.
when programming the Twido you dont usually add the E/Net port configuration unless you are are going to use it.
Hi I was downloading a program to a Twido TWDLCAE40DRF PLC base when suddenly i got disconnected. It wasn't a power fluctuation, the Twido PLC...
2,727
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
231
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
894
Hi, Have very basic knowledge of PLC's. Wondering if someone can point me in the right direction. Our assembly equipment is being run off of...
1,180
Hi, I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange)...
922
