Board style PLC's
Lionel
Guest
L
Hey Everybody
I am just getting into the PLC world. I am going to be designing
circuits using PLC's and I want to use the circuit board style.
I have looked into using Entertron Industries. They are very helpful
and are willing to work with you. Are there any other companys that
make the style that I am requesting?
I don't think you'll find anything like Enertron, at least
nothing thrifty and usable and available with any kind of
tech support.
Loinel,
Look at the Omron CPM2B, it uses standard Omron software and is the same platform as the CPM2A PLC.
I have used this on a few applications and it is very easy to use and is reasonably priced.
Mike
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
144
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
282
I have a old lathe with a 120 VCA 9.5 AMP motor. Has white, black and red wires. I need to find a way to connect it to a variable speed controler...
104
Hello Everyone, Does anyone have any suggestions or experince with a message board that could read a tag from a PLC, or have a PLC send a...
685
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
546
