Bode plots of motor and load
Plc_User
Dec 2005
Belgium
317
Can someone give some good pictural examples of bode plots (amplitude in decibel, and phase in ° in function of frequency in logaritmic scale) of a system with electrial motor with gearbox, connected to a load. Considering there is some degree of torsion and friction in the system?
No gear box. The gear box only changes the apparent load.
http://deltamotion.com/peter/Mathcad/Mathcad - DC Motor Velocity.pdf
I was showing how I would approach the problem shown here.
http://www.engin.umich.edu/group/ctm/examples/motor/PID2.html http://www.engin.umich.edu/group/ctm/examples/motor2/motor.html
Much of my pdf was done to show how one can calculate the relative ratio of the inner loop bandwidth to the outer loop bandwidth. I wanted to debunk some myths and show how following the myths may not work at all.
Hi Peeps, Currently learning PLC's so very much a beginner, my college requires using PLCsimulator for screenshots... small problem with no abode...
2,589
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
290
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
237
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
336
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
170
