Bristol Object Server to GE IFix 5.5
Oct 2011
New Jersey
Does anyone have an example of the structure of the addressing required to use the BB OPC server in IFix. I have only used the BR3 driver in the past so I do not know exactly how the addressing should be formated.
Any help would be appreciated.
Thank you in advance.
In iFix, select the correct driver to match what the Bristol Object Server uses, then look at the online help for proper syntax. You may need to read some documentation to determine the driver needed.
I'm installing an HMI for an existing RTU. I have a spare control wave I want to dump the program into to test it before I go to site, however...
269
Does someone know what is the function V_ATTRIB_GET? I can't any information about it anywhere in the internet.
378
I am looking for someone that may have copy of ControlWave Designer or OpenBSI v5.9. I am looking to do some testing and from what I read there is...
808
I am looking for someone that may have copy of ControlWave Designer or OpenBSI v5.9. I am looking to do some testing and from what I read there...
809
Yes you read that right. I've got a lone Bristol Babcock 3330 out in our system that I need to replace. The plan is to go to an Allen Bradley...
1,556
