Button on Excel to toggle a bit in RSLogix 5000 - using FTLinxGateway
squiggz
Apr 2021
Asheville, NC
23
I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx Gateway and I'm starting to learn the ins and outs of it using DDE. I've got going from the PLC to Excel pretty down pat, but I'm struggling with figuring out how to go the other way.
Thanks.
It is an interesting question, but the responses so far are just bad!
FTLinx use OPC and not DDE.
Search Rockwell for:
FactoryTalk Linx Gateway Excel Sample Instructions
If you want to use DDE, then search for : FactoryTalk Linx Gateway DDE / RTD communication set up in Excel
FT Linx Gateway definitely uses DDE. I think it started a couple months ago.
But thanks, I'll give that search a try.
Hello, I want to send the data from Rslogix500 to Excel. I created a connection between RSlinx and Excel. The values in Excel automatically...
1,186
Hi guys, It is possible to execute the Excel.exe when I click the button at RSView32? Is there anywhere we can do this without doing any VB...
6,312
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
132
FactoryTalk View ME running on PanelView Plus 7, connected to Compact GuardLogix 5380 PLC Customer is asking for a physical push button to be...
184
Hi everyone Is it possible to change a button image in FactoryTalk View SE (v13.00) using VBA?
86
