C-H PanelMate to AB SLC Addressing
SLaubach
Apr 2002
PA
152
I am trying to add screens to a PnlMate Powerpro and am running into some addressing questions. Currently an existing input in the AB is addressed I:12.3/3 (RIO CARD) and in the C-H program it is addressed [B:C 12/3] how is this screen getting to bit level? am i missing the obvious? I tried Knowledge base on CH website but it must be down and i have no user manuals to refer to here at the plant. Please Help
scott
I havent done one of the PnlMate Powerpro's in a while but I'd guess that the thing is ignoring the ":C" in the address and resolving it to [B12/3] which is shorthand for B12:0/3.... and all without giving you an error message
Perhaps somewhere in the program the I:12.3/3 is being copied ot B12/3 as in:
I:12.3/3 B12:0/3
Hope this helps
That's an odd looking address. Are you sure its not a tagname? I'm not sure why anyone would create such an obscure tagname. Which AB driver are you using?
PanelMates are supposed to use the same addressing conventions as the PLCs they're connected to. You should be able to use I:12.3/3 for Input slot 12, word 3, bit 3.
According the PanleMate driver manual for AB PLCs, the format for the address field should be xf:e.s/b.
Where x = File Type (B, N, T, C, etc)
f = File number
e = Element number
s = Subelement number
b = Bit number
The .s and /b fields are optional
Based on that, I'm not sure how to interpret B:C 12/3 Spaces are not permitted in the address field.
Have you tried running a verification check on the configuration?
I am still trying to figure this out steve, i also tried your suggestins. CH support (online) was quick to respond but didnt tell me anything besides download .pdf files, their website must have bad links becouse i cant download anything.
scott:
If you want I can e-mail the section of the .pdf file pertaining to the AB interface. It's about 230k.
You can e-mail me at the address below and let me know.
I have seen problems with different manufaturers addressing.
Some have the least significant on one end of a register while the other I'm trying to interface with is on the opposite end. (1=16)
And then another manufacturer's LSB is 1 while another is 0.
Throw all that into the mix and you got to have a
"Handy-Dandy Conversion Chart". I'm not familiar with
C-H's Adressing but it's something to think about.
HI FRIENDS... I have a Panelmate 1100 and i need connect it with slc503 using df1 driver... I downloaded the serial drive to panelmate and i draw...
1,691
Hello and thanks in advance for any help you can give. I have a SLC 5/04 processor and a Panelmate Power Pro 3000. There is an AIC+ Advanced...
12,183
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
519
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,153
