C-more Numeric Display Background Color
Archie
May 2002
Orangeburg, SC
1,944
This is my first project using a C-More, so I may be overlooking the obvious. I have a numeric display for a measurement that I need to change green when passing and red when failing.
I don't see any way to dynamically change the background color. Neither do I see a way to make the background transparent and overlay the number on an indicator.
Any recommendations are appreciated.
Try overlapping two different numeric indicators - one with a green background and one with a red background. Set the visibility option (in the "options" tab) to only allow the numeric indicator with the correct background to be visible when the parameter of your choice (tag) is OK.
I was thinking along that line, but thought maybe there was a way to do it without having an object that can't be seen in the designer.
I did it with the overlaying objects and it gets the job done.
Thanks!
When ever I have to use numeric displays with different colors depending on results, I just use the Visibility option and multiple copies laid ontop of each other.
Maybe they should work on something like a "multistate numeric display" for a later firmware update.
Speaking of multistate numeric display... is there a way to imbed your variable in a multistate text indicator? That might work, if possible, I haven't tried it.
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
121
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
115
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
282
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
193
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
511
