C600
Mmancillas
Feb 2010
Long Beach
20
Hello guys,
I am having a problems with a AB panelview touchscreen C600 Cat#2711C-T6M.
The original complaint was that the screen would frezee after pasing the initial test. The scrren will boot to the first screen and that is as far as it goes.
This HMI is connected to a micrologix 1200. The plc doesnt seem to have any issues, I was able to interface using RS-232DFI devices drive from RSLinx. I did try interfacing directly with the panelview using the same protocol with no results. I have also try running my comunication cable thru and AB AIC CAT 1761-NET-AIC just in case my cable was the wrong one.
I can see a usb port in the panelview, but I should have been able to interface thru the AIC in any case.
I would apreciate ypur help.
Thanks,
Manny
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,268
I have a client with a problematic PacDrive LMC600. It also has a separate PNC_Controller (Profinet) module. The original problem with the...
1,950
Have a C600 Panelview that the display went out in it. It still has the configuration in it and the equipment is still running. Believe it is just...
1,615
we have PanelView Component C600 (2711C-T6T) and want to modify it, try to install PanelView Component DesignStation V4.0 in my laptop and one...
2,724
Hi All I have an issue with the PV800 (C800) panelview. I had to upload the C600 program first. Then using CCW, i created the new program. I...
1,202
