Cabinet Over Temp Relay
glaverty
Apr 2002
Parts Unknown
509
We have a customer asking for a contact relay closure if the temperature in the cabinet gets too high. Does anyone know of such a device, I have never had to use one before. It would also need to be Class 1 Div 2.
Okay, do you have a way to sense the temperature? Do you have something already that can read the temp. and fire an output?
Do you need everything, sensor , controller, relay?
Sounds like something a regular room thermostat can do. If it's in a purged cabinet it won't need class 1 Div 2 rating. Otherwise you should be able to get a thermostatic switch from United Electric with the right approval.
Roy
I'm looking for something that is all in one, you wire up to it and if the temperature is over some temperature (not necessarily a temperature I have to set but could be pre-ordered) then the relay closes.
I need to monitor the temperature inside the control cabinet and display it on the HMI as well as send an email if it gets too high. I have a...
2,274
I am in need of some cabinte temp sensors to be able to know when the cabinet ac is on the fritz and seta alarm. It would be nice to have...
3,517
I am looking for something to detect cabinet temp. Prefer din rail device if possible and i wanted a analog output value so it can be sent to the...
2,391
Hello to Everyone! I am looking for Ethernet/IP Distributed In-Cabinet IO Block options to talk to Compact Logix PLC (L36ER). I only need 3 DO's...
2,989
i have a customer who is pushing back on something i have not encountered before. the cabinet is a local control panel consisting of PL, PB, HMI...
4,549
