Cable diagram for OP17 to S7-314
bundhit
Sep 2003
Bangkok
39
In case I short a stock of DP-Connector and Pofibus cable, Could I use DB-9 connector and multi-core signal cable in stead of them to connect OP17 and S7-314? If the answer is "Yes", what the cable diagram shall be?
Hello bundhit;
If you are using MP or DP connection (even though there is no DP port on a CPU 314), pin-to-pin on pins 3, 5 and 8 will be adequate.
Look at the following image:
The 24 V power and the RTS signals are not used for Profibus connections; for MPI ports the 24 v is often used to power local instrumentation (power for the PC-adapter, for example). But it is not required for connection to an OP.
you must take into account the fact that this solution does not give you the termination required for a run longer than 10 m. at 1,5 MB. you will have to take care of this yourself.
Hope this helps,
Daniel Chartier
What is the symbol for a Ethernet cable on a Loop Diagram?
825
I need a pinout for a GE cable 336A4929G1. Thanks
3,190
Dear All, Pls help me to make a programming cable from Rs232 to Rj45 for Fuji(SPE) NW0 plc.Please please please. [email protected]...
1,444
Hello guys, Can any one please share the communication diagram of Micro logix 1400 channel 2 RS 232C pin wiring configuration...
6,715
Greetings everyone, I'm looking for a pinout/wiring diagram for the AUI adapter cable part # P0970XF. Much help would be greatly appreciated!
1,255
