call specific pdf file in factorytalk
macgioo2
Oct 2009
Cambridge
98
Hey guys,
I'm trying to call a specific pdf file from a button in factory talk but all I can manage is to call the program (Adobe)
i.e.
AppStart c:\prog_name
how can I access a specific file related to this program?
Have you tried:
AppStart <progname> <arg1>
where arg1 is the PDF file name
OR try making a windows shortcut to the PDF file and as long as the .pdf extension is associated with the adobe program name this may work
AppStart <shortcut>
hey,
Yes this works thank you, I was able to find another way using VB:
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Sub Button1_Released()
strDir = "c:\"
strFile = "test.pdf"
ShellExecute 0, "OPEN", strDir & strFile, "", strDir, 1
End Sub
The only trouble is that neither of these bring the pdf up in front of the running application. This is very important for me as its touch screen and will have no keyboard to toggle between screens
Edit regestry.
\HKEY_CURRENT_USER\Control Panel\Desktop
Find the item ForegroundLockTimeout and set value to 0.
Hello everyone. I am working on designing a call light/alarm system I have roughly 20 stations that will each have their own call switch. Then...
20
512
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
144
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
702
I created this FC and it compiles, but when I use it in my MAIN OB1, it appears to have two outputs. See pictures. What am I doing wrong here...
1,493
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,999
