Camera image displayed on a Siemens TP277
Mrslipmat
Mar 2009
Inside a cabinet somewhere....
199
Hi Gents
I was wondering if anybody had setup a system where a live camera image was displayed on a TP277 touch panel with ethernet, The vision inspection camera I have has ethernet capabilities and can connect to the screens port. fruitless searches of the net have come up with nothing so I was wondering if it was possible at all to do this.
So far looking through WinCC all I can see is smartclient view that has lan connection settings etc... Am I looking in the correct area ?
Regards and Merry Xmas to everybody
John V
Thanks for your Promt reply Jesper... Shame it won,t seem to work, there is a possibility I will have to use a seperate screen to display the image as I am tied to using the TP 277 screen at the moment...
Regards
John V
It,s a TCP/IP output and ethernet I/P output.... Its the new vision camera from IFM, 02V series. The camera itself can be setup to give me allsorts of info over ethernet connection, passes, fails etc, this is the info I want to display along with the picture.
Regards
John V
Codesys FTP camera image to local hardisk, but bmp picture under codesys are load only when the plc starts, any function or setting can...
2,759
Hello! I want to write PC-software for measure length of hot rail after finishing mill via analysing image made by digital camera. Could you...
1,368
I have been tasked with the installation of a Flir Camera to Control Logix PLC via Ethernet. I have uploaded the AOP in the PLC and can set it up...
2,678
I was in a brainstorm session last week and we were discussing using maybe 2 Cognex cameras to come up with a 3D image. Using a ControlLogix PLC I...
3,712
Hi Everybody, I Have an issue with IFM 02d224 camera. the camera communicate with contrologix PLC by ethernet. there are two applications in the...
109
