Can a script do this? (flexible)
Mar 2008
løgstør
22
Hi..
I have a question about my flexible 2007 project for you experts.. :)
I would like to make a script that can print a screen when it is loadet. I have a page that contains a trend, that shows logged temperatures from a two rooms. I have created a scheduled event that activates the screen with my trend at 11.59 PM. Ant then i would like to print the trend. But the problem is, that it takes som time from when the page is activated and until the trend is loadet.
Therefor i was thinkins if i could create a script that prints the screen when the trend is fully loaded??? But i have alomost no experience with creating scripts - actualy i have only created 1 simple one before.
So i was hoping that some of you could help me on the way, or maby tell me if there is a better way to solve my problem.
Regards
Morten
Well, I dont use WinCC Flexible anymore, but I would try this:
Load a script on the onLoad event for the screen;
In the script:
  • Add a delay in the script (or even beter, in the plc). You can add a delay in the script by checking the Time when you entered the script, then create a while loop that loops untill (Time + n seconds)
  • Do a printScreen.
I'm not sure if this will work (or even if the printScreen function can be accessed in script). Just an idea!
In the script:
  • Do a printScreen.
Thanks for reply.
What you suggest is actually what i do now. I load the screen, and then wait a time, and then print screen. And at last i change back to previous screen.
But my problem is that it takes different time to load the graph. It depends on how many loggings it has to load. And then the time is not always the same.
So I was wondering if it is possible to program a script that is printing when the graph is loaded, and not after a preset timer..
I have 4 arrays. 1. -> arrdb1 (array of 52 bytes) 2. -> arrdb2 (array of 20 bytes) 3. -> arr1db300 (array of 20 bytes) 4. -> arr2db300 (array of...
3,528
Please help me for some reason I cannot get the loop to continue, it is based on a screen name and if the screen is on the start page the script...
1,956
I want to call an executable (or .bat-file )from inside a script using WinCC Flexible 2007. :scratch: Searching the net always seems to return...
5,601
Hi. is it possible to create a script in WinCC Flexible, that uses Xcopy to copy several (large) folders and create a systemmessage if the copy...
1,936
Hi, I have to convert my csv file to an excel sheet in Wincc Flexible 2008 for which I have written the following code snippet: 'Alarm_Log.csv'...
5,273
