CAN Bus Encoder on CompactLogix
'CAN Bus' is a general term; are you using DeviceNet, or CANOpen, or some other CAN protocol ?
CompactLogix has no built-in CAN port, so you'll need a 'scanner card' for whatever protocol you are using.
I recently saw a presentation on some EtherNet/IP encoders that can be used with ControlLogix or CompactLogix motion control as auxiliary axes. Pretty neat !
Thanks for the reply. The issue is I am upgrading a machine which currently has 4 MTS CAN Bus encoders which are wired to a Moog rack. We are replacing the Moog valve with Rexroth and need the ecoder values in the compactlogix processor. I found an Anybus converter that may work but not sure.
I guess I wan't totally clear. The machine has Can Bus encoders on it currently.
I do not want to replace the encoders. If I did replace them I would use DeviceNet encoders.
Hi everyone, I'm hoping someone has some experience in this because I'm at wits end ready to tear my hair out lol. I have a SP5000 Series Proface...
1,964
Hi, Can anyone recommend a good profibus encoder that can read the speed of a shaft? I'll be using it on a S7-300. Thanks
1,782
Hi Everyone, I want to know how i write a program in S7 300 plc of absulate encoder profibus dp 32 bit.
2,555
At my work, we have Controllogix 1756 L71 with DI, DO, and a servo card (1756-MO2AE). Today, a DI terminal was occasionally not registering input...
2,078
hi to all please help how to cfommunicate s7-300 cpu to elco profibus encoder, also show me the sample program using any profibus encoder...
1,632
