can i produce sound using IFIX alarm event ??
atifplus
May 2007
Surrey
121
I dont see any option in database manager
all i see how i could show those in alarm summary ??
:) also would be great if i could configure the type of beep i get
plz post if u knwo the answer
Atif
oh okay if there is a alarm sound manager where is it
and why i can't see it do we have to buy license for that or what??
or is it in the installition :S
The simple method, to me, is to use output(s) for alarms. You can either use different outputs that drive different alarm horns OR you can setup a single output to make different signals i.e. 3 short burts, or 3 long bursts, or ??? It is also possibe to use an analog output to make WAWA sounds or any type of oscillating sound.
Usually SCADA or HMI just provide information telling what an alarm is for, the actual action is developed in the PLC.
Usually there is a section allocated for Alarms but I have no idea about Ifix, someone may be able to assist with that.
BTW: I have developed some fairly simple programs that the alarm section took an equal if not greater amount of memory.
I have not used IFIX but in FIX32 you have this:
haha Ron i have an output already that is driven by PLC for that alarm. I have a strobe light with alarm hooked up. But now i want to do it on IFIX so supervisor and operators can also notice it and could direct people to take whatever action need to be taken..
I was reading it somewhere last nite that u could use different wave files. oh man that would be super cool. to tell people what exactly the alarm is .. like "EVAC EVAC" :p haha jkjk..
but ya forgot to bookmark that site last nite :( if anyone knowz about that trick i would like to knwo so plz post and share ur knowledge :).. lol maybe the horn manager have this option i will go dig in to find the cool features:)
Thanks again guys
I used specterinstruments.com to dial plant page for Chlorine alarms. I created wav files to say whatever I wanted to say. This was for FIX not iFIX. Though, I believe it would still work.
George
Awesome :)
There are lots of text reader available for voice selection. I enabled the horn support and all i could hear is 3 different beeping sounds according to the priority.
I dont see the Horn Support manager or any option to go to that application where i could make changes to sound selection of wave file.
Screen shots would be really helpful like the one Mickey put up.
Maybe it is not for IFIX .. coz if that is the case there will be lots of alarms and person will go crazy coz of all those beeping ..
IFIX is a cool software lots of new tricks and stuff and VBA support make it so powerful.
atifplus,
Again this FIX32 ( as I dont't have IFIX) the below command script plays a wav file. I knew a co-worker who programmed it to play the "Star Trek" theme when a new alarm occurred.
waaah mission control seems like this is the way to set
But I am getting this message on one of the tab
auto alarm manager thats what i been trying to seach.. seems like an additional feature we have to buy
oh i found this ODBS alarm config. application in dynamic folder.. this could be the one still not sure :)
some new stuff for monday :)
atifplus said:
huummm... still can't see that ALARM manager IFIX is talkin about
http://www.gefanuc.com/Downloads/en/auto_alarm_manager_productivity_pack_gfa797.pdf
You download this from the global care website,developer downloads section
http://support.gefanuc.com/support/search/ui.jsp
I'm not at work so can't give you any screenshots, but if you're using an alarm block you can assign a tag to be triggered when an alarm is activated, use this tag on each alarm. Then use it in schedular to activate a script that will play yor wav file.
Hope this helps
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
185
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,128
Recent Forum member and very-good-question-asker /DesertSurf520 has a thread that started a discussion about Compact 5000 I/O, but branched off...
1,860
My PLC has a Boolean consume tag that gets data from another PLC via ethernet. Is there a way to make the consume tag fail to 0 when the ethernet...
2,756
Hello Ladies and Gents, I have some PLC to PLC communications using Produce and Consume. The data is not time sensitive, and I really only need...
4,657
