Can I use GE proficy machine edition to program a Proface panel
Davev2005
Jul 2005
San Luis Potosi
23
hi,
Can I use Proficy machine edition to download a hmi program to a proface GP37W-LG11-24V panel?
I ask this because I see some panel labeled Quick Panel Mini GE Fanuc, others use QPM too just change to CTC or Total Controls...
thanks in advance.
Cool!!!
I will have to try it for a current project.
That is why I posted that way. Sometimes the local supplier gets it wrong. They also told me years ago that LM90 would not run under Windows XP - absolutely false, but I had to find the answers myself.
Some times there is a difference between "can I" and "will it work"?
If one is competent and does not need factory support, go for it. Just remember that "if" you run into a problem you are on your own.
Also there is a difference between "will it work" and "is it supported"? Most reps do not have time for a combination that is not supported by the manufacturer.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
125
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,402
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,280
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,040
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,036
