Can I use Modbus protocol with a CPU314-C2 PN/DP?
Iner
Mar 2010
France
190
Hello,
I am trying to use the Modbus TCP protocol from the Siemens library to communicate with a Telemecanique Premium. I have a working exemple on a CPU315 but I keep getting an error on this one.
First the licencing (which is not necessary to run the communication, there is just a red led flashing). Then a status connect oscillating between 7001 and 7002 (no idea what it means).
The Wizard tool I have to parameter the Modbus DB makes no mentions of the CPU314 when he asks to choose the local configuration.
That's why I am starting to doubt? Is still possible? I need something else? Anyone got an answer? Thanks.
As far as I know, there are two separate libraries.
One is for integrated PN ports.
The other is for CP343-1 (should work even with the LEAN model).
The library I have is for integrated PN ports. It works with the CPU315.
Does it work for the 314-C2 ?
Hello Guys, I have been trying to study a Machine that have Omron 3g3mv VFDs that is controlled by CJ1m CPU and SCU41-V1 communication card. The...
482
Hello Guys, I have a packaging machine in the company that I work for that have 8 Omron VFDs (3G3MV ) that are controlled via Modbus with CJ1M...
661
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,735
I am finally lucky enough to work w/ an actual high level programmer. I can follow a tag from the pnp junction up to an hmi. He knows the other...
20
5,820
Hi! Please share the MODBUS protocol code for the subject Regards
2,455
