Can someone explain what motor absorbtion is?
Absorbed power is the expected power drawn by the load. Most loads does not operate at its rated capacity, but at lower point. The motor is typically sized so that the rated capacity of the motor exceeds the expected absorbed load by some conservative design margin.
http://www.claredot.net/en/sec-Electrotech/calculation-motors-parameters.php
http://www.sugartech.com/motorpower/index.php
If that helps, credit goes to Google, if that does nothing for you... well thats Google :)
Hello all, I have recently been working on a project utilizing Allen Bradley PLC/HMI. It's an L16ER-BB1B PLC and a Panelview Plus 7 HMI. I'm...
5,737
I’m using rslogix5000 v20 with ControlLogix L72. I added some rungs to monitor time meter of our propulsors. But with same ladder instruction I...
4,028
This is a bit of a rant lol, my first 5 years as a systems integrator was using Siemens, then I came to the dark side of Allen Bradley / Rockwell...
67
23,800
I'm going to be working on some InTouch and System Platform projects - I've not worked with WonderWare before and am wondering if someone could...
6,814
How can the address in the picture work in the Fuji D 0304-E and not work with the Weintek HMI how does it use the -E because in the PLC program...
3,003
