Can someone reccommend a drive with PID & inverse PID output?
strantor
Sep 2010
katy tx
401
my application is a respooler. A spool on the takeup spins at constant speed, the payoff(5hp motor) is PID controlled. Currently using a Yaskawa V7 drive. My current setup does not have enough braking power so I am adding an air brake. I need the air brake to be controlled by an I/P transducer which is controlled by an inverse PID output of the drive. The yaskawa has no ability to do this. I need a drive with a multifunction analog output able to be assigned as Inverse PID 4-20ma or 0-10v. Any drive selection reccommendations?
Also, does my adding an air brake controlled by I/P transducer Idea sound like a good idea? any reccommendations on that?
Depending on the speed, a brake alone should be sufficient (with no motor), unless you need jog/thread functionality.
You didn't say what your feedback device is, but consider a simple process controller like the Moore 535 or similar.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Long story short lost our parameter setup for an indradrive m. I have these files saved as backups but dont know how to open them. Can someone...
906
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,110
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,632
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,604
