Car wash PLC
Martin_Parker
Oct 2002
I`m a student from the UK, as one on my PLC assignments i am to design the PLC/electrical, side to a carwash, as venturing through the internet i have found no help with this and am in desperate need, can someone help,
Thanks Maritn
Martin,
Generally speaking, you will usually want to ask more specific questions than you have here. But I want to give this a shot anyway.
Since you seem to be stuck at the very beginning of things, I am going to focus on how to get started (not on how to program it):
First: define the goal,
Second: identify actions (outputs),
Third: identify things we watch (inputs),
Last: identify the dependencies (logic).
1) Define the Goal : Usually this means that someone (maybe you in this exercise) must define all the individual functions that make up the machine. So for now, lets assume this is your job. What are we building? You say "a carwash", so lets further assume you are talking about an automatic carwash. For my answer I am going to say that there are three cycles to this car wash: Wash, Rinse, and Dry.
2) Identify Actions (Outputs): For the Wash Cycle you obviously have supply water so lets open a valve. We also want to scrub a little so lets rotate two vertical brushes and oscillate one overhead brush. Because of various car sizes, these brushes will need to move in/out and up/down, respectively, we will turn on reversible motors for each of these actions. We want to pull the car through so lets start a conveyor motor, too. You need to do the same for the other two cycles as well.
3) Identify Things We Watch (Inputs): We need to be able to start and stop this thing, so we have a "Start" button and a "Stop" button. We want to accommodate different height cars so we need a "height" sensor. Similarly, since different cars are different widths, we need a "width" sensor. Once again, you can do the same for the other cycles.
4) Dependencies: Now that you have defined the inputs and outputs, all you have to do is exercise you gray matter and decide which inputs need to be used to make which outputs do their thing and then write your program.
Now keep in mind that GOOD programming and system design require a lot more consideration than I have talked about here, but I am just trying to help get the creative juices flowing.
Steve
Hello everyone! I have an enormous project ahead of me that has somewhat reached beyond my knowledge of programming. I recently purchased an old...
4,293
Hi, I am a student in the UK studying for my HNC in Engineering, part of the course are PLC lectures, as i have not encountered them before i...
9,625
Company that orig. built equipment is gone. I have the program. Customers are looking for features like: email alarms door control remote access...
17
6,623
Hello I am trying to figure out how to use sequencer and I am not very familiar with it this is what I got . LS1 turns on water LS2 turns on soap...
2,278
I am looking for a little critiquing on my car wash ladder logic diagram that isn't working that well. As well as I want to put in a door program...
25
5,487
