Cartridge style load cell for web tension
allscott
Jul 2004
1,332
So I've been handed a cartridge style load cell (Andantex 801.025.sc.1.25) that was purchased for a web tension project. I have never seen anything that looks like this before. This may sound like a stupid question but can someone tell me in what axis this thing actually measures force? From what I can tell from scouring the net these should be used on idler rolls and measure the axial force being placed on the rolls, is that correct? This is uncharted territory for me.
Thanks in advance.
These are very common. Yes, they are typically mounted on an idler roll.
So your doing a web line?
A very rudimentary one yes. I am paying off mylar tape that is being pulled into a machine, I need to control the tension on the payoff brake.
Unfortunately the mechanics started this project without consulting me. The transducer they bought won't work. The way they have designed this system I need a regular load cell like for a scale. The frame for the idler roll they designed will be pulled up to a fixed stop by the web. I need to calculate the force against the stop as feedback for tension. This is being fed to a controller that is controlling a magnetic brake on the payoff for the web.
I think what they designed will work they just bought the wrong type of transducer for the application which is why I was thrown for a loop.
What are you doing to make sure the idler roll frame doesn't hit the load cell like a hammer when it gets to the stop? Keep in mind that F=ma and "a" gets REALLY LARGE when you have metal to metal contact.
I guess I don't understand why you wouldn't use a cartridge style loadcell in this application. Also, load cells like this measure radial force. The design of the loadcell USUALLY measures force in the direction of the fixed collar (as opposed to the removable cap) but there should be an arrow on it indicating the force direction.
As an aside, Andantex looks to be a rebranded CMC loadcell. You may find more info on the CMC website.
Keith
Keith
Actually I had the mechanics down and we are going to modify the machine to use the cartridge style load cell. The reason I thought it wasn't going to work was because it woud be in the way of the web but we will just modify the frame a bit so that isn't an issue. And your right I had never thought about the arm banging against the load cell. The machine starts off fairly slowly so I don't think it would be a big issue but this is probably the proper way to do it any way.
Thanks for your help.
I have recovered 4 data carts for a PLC-2. The program that I have is pretty much useless (Ladder only no descriptors 712 rungs) THANKS JOHN...
4,059
Im trying to diagnose a loud vibrating/humming noise coming from my companies Kollmorgen Cartride Direct-Drive Rotary motor. The motor is being...
606
Hi All, I am using TMC2TI2 cartridge M221 - 2 temperature inputs - I/O extension with TM221CE16R. Is it suitable to use RTDs with this I/O...
1,180
Hi! My friend is an electrical technitian who wants to know if it's possible to build a DIY memory cartridge with an EEPROM for use in S7-200 PLCs...
1,156
Hi All, I've got an S7-200 PLC up and running with a battery module installed. I also have a copy of the PLC program (i believe) on a 64K Memory...
2,188
