Cast Iron vs Rolled Steel Motor
alive15
Oct 2015
Montgomery, AL
722
Good morning,
I am looking to order a motor online, and it comes in both cast iron and rolled steel. Which one will have a longer life in a very harsh environment? There will be lots of saw dust and debris in the location of the motor.
Thanks,
As far as longevity both would be about equal
They mage have a different frame size To consider.
For your application I would recommend a TENV frame and monitor the temperature of the motor. When dealing with wood chips the last thing you want is the motor overheating and starting a fire.
Frame size will dictate which you use in most cases. Cast iron has cast iron end bells and is for larger shaft applications. The rolled steel are normally lighter and run cooler than cast iron because the cast iron has the defined fins where the rolled steel pulls cooling air across the smooth outside surface.
Because of the cast iron cooling fins they are not good for places where they would get wood chips or sawdust in the cooling fins for example as that would make them run hot. The rolled steel having the smooth outside will not trap saw dust or wood chips. They may pile up around it but the running motor and the smooth outside will keep it from piling up. This is just one of many examples and scenarios.
Cast iron is also normally the best choice for VFD over speed applications due to the heavier construction of cast iron it holds up better to the increased mechanical stresses of over speeding.
Dear, i know this is not a PLC question but i need to know what is difference between cast aluminum, cast aluminum epoxy coated and cast iron...
2,549
Hi everyone, This has been 2nd time I am getting into the same question that in which circumstances we check the Unicast connection over...
1,031
I have a few PLC's that will not use unicast, and they will not communicate with the Stratix 5700 anyway around that.
1,480
Hi Guys, I have doubt on which condition Unicast connection over ethernet/ip box will be Checked and Unchecked in the Connection Tab while...
1,364
Hello, Amateur Proworx/Concept user here. I am trying to add a default gateway but I am having issues. I have a few questions: In proworx 32 I...
1,881
