cat 5 tester
James Mcquade
Oct 2007
Nashville, Tennessee area
3,686
Hi all,
last week we lost our cat 5 cable tester.
is was a simple tester. one end was the return loop and the other was the tester.
the tester told you pass, which lines were open and if the cable was a crossover cable.
i have searched the internet "cat5 tester" and cannot find this type of tester.
if any of you know of a similar unit, please post.
thanks in advance,
james
Hi all,
thanks in advance,
james
Also check out Monoprice. They have a very inexpensive unit I use all the time.
http://www.monoprice.com/Product?c_id=105&cp_id=10524&cs_id=1052401&p_id=8138&seq=1&format=2
Hi all,
thanks in advance,
james
Would this not work?
http://www.amazon.com/TRENDnet-Network-Cable-Tester-TC-NT2/dp/B0000AZK08
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
99
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
258
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
117
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
85
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
170
